jean-michel
by the way for the Rolex specialists note that is is a 16610LV but I change the green bezel for a black one, that is why the watch have the "maxi dial"
Did you change the bezel using a standard submariner´s black bezel?
Ithought the LV´s bezel was 1mm wide than black´s and because of it the standard bezel was not compatible
great result!Congrats J.M.
Yes it is the standard submariner bezel and no the bezel is stictly identical on the LV, I have read this myth several times, but the two watches are strictly identical (including the engraved reference) the only differences between the two are - green bezel - maxi dial
cheers
Super-Pics...¡¡¡¡ :surprised:la::bravo:
la::bravo:
Thanks for sharing..¡¡
